You could use a sandwich adapter,plumb to that,and leave the filter in the stock location.quote:
Originally posted by BOBISTHEOILGUY:
Jeeper, I had been toying with the idea of using a remote filter kit no room in the engine compartment.
attaching a pressure gauge on the in and out of the two hoses.
Also Bob, There is no need to install two gauges
A dp gauge has two inputs(higher&lower)
It doesnt read the actual pressure in lines,
it registers the difference(no math).
sandwich adapterquote:
Originally posted by neilw:
Jeeper
Sandwich adapter???
It appears you are correct.quote:
Originally posted by GlenFord:
ports are both "upstream" of the filter
You'll also need a thermometer so you're comparing the differential pressure at identical oil temperature/viscosity.quote:
Originally posted by jeeper:
Been thinking of installing a differential gauge to monitor the status of my full flow.
Has anyone here done so,if so like to here your
experiences and observations.
