Hi guys,
I have recently done quite a bit of maintenance on the car and now it sounds like a WRX and has a heavy rumble.
Maintenance carried out:
Symptoms:
What I have tried/tested:
Any help or advice is greatly appreciated
- Replaced distributor o-ring (was leaking)
- New distributor cap + rotor
- New spark plug leads
- Ultrasonically cleaned injectors
- Replaced valve stem seals
- Lifters cleaned out
Symptoms:
- When I put my hand on the exhaust it fluctuates between pressure and vacuum (so my hand gets sucked onto the tail pipe, then pushed out etc)
- Though I have not driven it, the rpm hesitate to rise when throttle is given, so lack of power
- Sounds like a WRX
- Rumbles/vibrates quite a bit
- Checked spark leads are in correct spot - They appear to be correct
- Disconnected each spark lead out - idles worse on each lead taken out
- I have disconnected 3 of the front injectors, the middle one seemed to make no difference in idle. Replaced this injector with my old one but made no difference in how it runs
