Well, depends on how much money you want to spend. A grease that has served me well for over 20 years is Pennzoil 707L grease. Excellent wheel bearing and chassis grease. It's a lithium complex based grease.
Might also add that since your looking at the Mystik oil, the Mystik JT6 grease is also a good grease.
Both of those greases should handle all with no problem. The Pennzoil 707L was originally marketed as a wheel bearing grease and has been used successfully in many a race car, so heat is not problem for this grease. Also has good EP properties for things like ball joints, u-joints, etc. I know a lot of truckers that use the JT6 and swear by it.
Well, I'll continue where he left off and say for normal to severe automotive apps, not construction equipment/farm, etc. Also, same grease useable for boat trailer hub brgs, as well? Let me guess, one of those AL complex Schaeffer greases, right?
