I'm sorry, I should have given this in my original post.. below is the Spec'd size. Part Number: 51334
UPC Number: 765809513341
Principal Application: Acura (88-05), Chevrolet (85-88), Dodge (91-96), Ford (88-96), Honda (72-05), Hyundai (89-07), Isuzu (85-04), Kia (01-07), Mercury (87-91), Mitsubishi (89-98), Subaru (87-07), John Deere, Kobelco, Komatsu, Kubota, Onan, Toro & Yanmar Diesel
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.194
Outer Diameter Top: 3.252
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=22/40
Burst Pressure-PSI: 280
Max Flow Rate: 9-11 GPM
Nominal Micro Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.475 2.173 0.233
Is there an oversized filter for this one?
