I'd like to put a relocation kit on my Nissan Pathfinder to make oil changes easier, and to take advantage of the very common filter size that it uses, the Fram PH8A (FORD??) or equivalent. You can find this filter size for dirt cheap and in practically every brand. The kit, however, recommends the HP1, which I understand is a high pressure model of the same filter. Is this really necessary as those filters are much more expensive
