Hi to everyone,
I have a question about Generac Oil pressure switches that cause the engine to cut off if the pressure is low.At my Mom's house we have a Generac 4000xl generator with pressurized oil pressure and a switch rated for about 8 psi.When i cleaned out the carb and did alot of studying online i found the pressure switches tend to go bad in this model for some reason and showed that when you disconnect it,the generator starts right up.I looked all online and the cheapest i find a switch for them is around $20-30.I bought one for my dodge van and it was like 10-11 dollars as i recall.didn't know why a pressure switch would be this high and don't really want to run without one.i could run it like it is,don't have any hours on it,maybe 3 hours in the 10 years i've had it,just use it for backup and haven't needed it too much.anyway is there a cheaper alternative to these switches around 8 psi?are briggs and stratton ones cheaper or interchangeable? thanks for the help/suggestions.
