Buster,
Oil filters tend to get clogged eventually from insoluble organic particulates, ie sludge. With PAO/Ester synthetics there is very little sludge to clog the filter, so change intervals can be extended. I just finished running an SDF-96 oil filter for 12k in my truck; I then cut the case off of it and examined the pleats and it looked fine. The only thing I saw was tea colored oil and no sludge. If you do lots of highway driving this recommendation is fine ....
I saw an SAE paper by Mobil where they ran oil filters for 100,000 miles in over the road trucks using Delvac 1 synthetic and they still performed fine. These were Detroit Diesel, Series 60 engines where the oil filter would typically be changed every 20k-25k miles. In this case, the key attribute of the oil that allowed this was very fine dispersion of soot particles, so they would not agglomerate and clog the filter.
