Originally Posted By: il_signore97
Originally Posted By: 00Max00
Isn't M1 0W40 has stronger specs on paper?
Castrol EDGE 0W-40 A3/B4:
Name Method Units Castrol EDGE 0W-40 A3/B4
Density @ 15°C, Relative ASTM D4052 g/ml 0.841
Viscosity, Kinematic 100°C ASTM D445 mm²/s 13.5
Viscosity, CCS -35°C ASTM D5293 mPa.s (cP) 5800
Pour Point ASTM D97 °C -50
Viscosity, Kinematic 40°C ASTM D445 mm²/s 79
Ash, Sulphated ASTM D874 % wt 1.12
Viscosity Index ASTM D2270 None 169
Flash Point, PMCC ASTM D93 °C 240
Mobil 1 0W-40 Value
Viscosity, cSt (ASTM D445)
@ 40º C 75
@ 100º C 13.5
Viscosity Index 185
MRV at -40ºC, cP (ASTM D4684) 31,000
HTHS Viscosity, mPa•s @ 150ºC, (ASTM D4683) 3.8
Total Base Number (ASTM D2896) 11.8
Sulfated Ash, wt% (ASTM D874) 1.3
Phosphorous, wt% (ASTM D4981) 0.1
Flash Point, ºC (ASTM D92) 230
Density @15.6 ºC, g/ml (ASTM D4052) 0.85
Stronger in what way? All you can do with the above data is make certain assumptions, but draw no real conclusions as to which will protect better. Mobil 1 has a higher VI, but that is not necessarily better (or worse) from a wear protection stand point. It also could mean that it has more VII's in it propping up that VI number. We know that Castrol is mostly (at least 50%) PAO, whereas Mobil 1 has been Visom (Group III+) for many years now (it could be making it's way back to PAO though). This could mean that the Castrol may have better extreme low temperature performance, but usually most people won't ever test an oils' lower limits in the US anyway. Mobil 1 uses a calcium based detergent, and features boron and moly (IIRC), whereas Castrol uses less calcium with a bit of magnesium, and a titanium anti-wear additive.
But we do know for sure that both oils meet many of the same stringent specs, so they can and should be considered equals for the most part.
Buy whichever you like, both will perform very well (I have used them both myself interchangeably for many years).
According to the MSDS, M1 0w-40 is 50-60% PAO now (again).
Both are excellent products that meet basically all the same OEM performance specs. Performance should be essentially identical. Choose whichever you can get cheaper.
