I happened to notice your comment combined your sig showing you're using the Gonher made Nissan OEM 15208-65FOE. You might find the linked thread interesting as to what I found on the same filter. Also, though other members unaware at the time, their's showed same result/issue. The words "here" in the OP shows the same result. One more difficult to see because photobucket overwrote, but it was clear enough to see before pb did that. Possible design has changed since posted, but not likely I'd think. Had I not cut it open, wouldn't have known. Just a heads up.
This filter a dealer installed Gonher made oem off a Rogue. It was on ~4700 miles, ~6months. Had a wide pleat at seam pleat, but no tear(s). Biggest issue as topic noted, the adbv. Prior to opening the can I had noticed the Rogue had a start up rattle and very little if any oil came out of inlet...
bobistheoilguy.com
