Originally Posted By: Gary Allan
Originally Posted By: blueiedgod
Even with regular 1 qt. jugs most people pour it from the wrong side. Try pouring it a different way.
I've seen visual aids on the quart bottles showing you to pour it a certain way when the spout is biased to one side ..like some are. I can't call it intuitive or counter intuitive for the very reason that not all quart bottles are constructed the same ..and, last I checked, I didn't miss the "principles of oil bottle pouring characteristics 101" in my life skills classes.
I guess I would have to call it counter intuitive to keep the spout further away from the target site ...which is what the visual aids depict on those bottles that have them. Add 4-5 more inches of fudge factor
Antifreeze was always a side-tip deal ..but rad caps tend to promote that action ..or rather ..enable it. Can't say that for oil filler locations.
I just switched from Mobil 1 to Pennzoil Platinum, and the necks on PP are much narrower than Mabil 1. I just stick the bottle into the fill hole and let her drain.
But, yes, with Mobil 1, you have to position the bottle with the neck away from the fill hole, this way air can enter the bottle and avoid the "glug, glug" effect.
I have not seen the 5 qt jugs of PP, but would assume the same principle applies there.
