Originally Posted By: UncleS2
For extremely short version- go to bottom of this post.
Something digital, with presets? That way she could scroll through the preset stations- you could set those up for her. All through the late 1990-s till now Sony made boomboxes that might serve very well for this- and they also had CD & cassette player. Some came with remote controls too. But even the volume control is push-button on them. I had one set up for my mother to use as a bedside radio & she never did really learn to use it. Might well be the same for the lady you know.
Or something old-school analog- dial tuning, on/off, volume, & that's about it? At age 82 she may well prefer this, and there are several good choices. Just to see if she likes it OK, you might try a Sony ICF-10 for about $15-$16 at Amazon, or a Sony ICF-38 for about $25.
The Sony ICF-10 runs on 2 D-cells only- but it'll run for a *LONG* time on alkalines- probably 200 hours+. It does *Not* have a handle, but does come with a thin carry strap. Whip antenna tilts but does not swivel. Simple knobs for volume & tuning both protrude from the front of the case. On/off & band-selector are combined into one 3-position slider switch, Off-AM-FM. Tunes AM up to about 1630 -1650 KHz. This model probably available Internet only.(it's really made for the middle east & Asia and has only recently been sold in the USA).
Sony ICF-38 runs on 4 AA cells(fresh alkalines about 100 hours- or maybe a lot longer, depending on volume & hrs/day) *Or* you can plug it into the wall- both cord & transformer are built-in, as is a fold-down carry handle. Whip antenna tilts and swivels- for a bedside radio this can be very important. Volume and tuning controls- wheels that protrude out of the RH side of the case. On/Off- a single dedicated switch that does nothing else, located on top of the case. Band selector switch- on the front of the case.Located between tuning & volume wheels, a high-low tone switch. Tunes the full USA AM band up to 1700 KHz. You might find the ICF-38 at Sears if you prefer to buy locally- otherwise Amazon's gonna be tough to beat.
Note- At 82 I doubt she uses headphones, but just in case, you need to know this: Both of the Sonys have a mono earphone jack- to use regular stero headphones & get sound to both ears you'll need a 1/8" mono-to-stereo adapter. Then you'll at least get to hear things in double-mono.
I own both of these, & my Mom used a Sony ICF-36(predecessor to the ICF-38, same except for now useless analog TV channel tuning) as her bathroom radio for the past 6 years or so, until her death last May. She really loved it, would crank up the classical music station while in the shower. Either of these is small enough to use with batteries as a laptop/move-it-around/chairside radio. For the lady in the nursing home, I'd really recommend the Sony ICF-38 for a good first try.
The much more expensive C Crane CC Radio EP model is substantially larger and heavier. I would not recommend one, at least until you know she has decent radio reception and can leave the radio permanently on a table or shelf.
Whatever you get, realize that radio reception may be very poor in the nursing home, & the radio may well need to be set in front of a window.
Short version- for a portable, start with a Sony ICF-38 AM/FM portable. I have experience with everything but the blindness & that's what I recommend.
+1 on the Sony ICF-38. I went through this with my Grandmother a couple years ago, anything with a digital tuner was difficult to operate, and the less knobs/buttons the better.
