Counting the threads or "feeling" the slack is not the way to correctly set or verify pinion preload. Nor is marking the nut which some do. Only real way is to correctly prep and measure it with an inch/pound torque wrench.These later rear axles are even more challenging because the pinion nuts are staked. The last ones I did I replaced the pinion nuts with new. Sounds stupid but I also measured the amount of pinion threads protruding out beyond the pinion nut before removing. I felt like that may be a good reference for how far to run the new nut back down. Of course stopping and checking the slack/feel all the way. Too loose is probably worse since that will definitely eat the ring and pinion gear surfaces…
