I posted the following on the mazda3forums. I would like some opinions from you guys as well.
( http://www.mazda3forums.com/index.php?topic=73195.0 )
OK guys, check this out. First some history. I have a 2006 GT ATX HB with 17,780 miles, stock suspension, 17"x7"x48mm lite weight wheels wrapped in 205/50/17 Kumho SPT's. I have been using Torco SR-1 5w-20 synthetic oil since the 1,100 mile mark.
I reset my on board trip computer the day I changed to the Torco, and I have still not touched it since. It reads 28.4mpg, and has done so (give or take a tenth) for 16,000 miles. I use the old fashioned (but correct) "fill the gas tank every time, and reset the trip odometer every time and then divide the total miles traveled by the gallons filled" method and here's the kicker. The best I have ever done while using the Torco SR-1 5w-20 was 29.6mpg. I have NEVER in over 17,300 miles of driving hit the 30mpg mark.................NEVER.
I recently switched to Valvoline Premium Conventional 5w-20 oil. I ran a quick 50 mile run with the Valvoline, and then I dumped it (and the filter) out and I refilled with 4.5 quarts of more Valvoline 5w-20. That way I had a quick "flush", so that I knew any improvement or lack there of, would be from 100% Valvoline conventional oil. I then filled up with Chevron 87 octane, reset the trip odometer, checked my tires' psi and off I went.
I have had the Valvoline in the motor for only two fill ups, but get this, I averaged over 30 mpg on both tanks!! #@$%!? In over 17k with high dollar Torco I never hit 30mpg once, and on my first two tanks with good ole inferior dino oil, I hit over 30mpg both times (30.2 & 30.1).
I am almost OC about my cars maintenance. I check my tires psi bi-monthly (every month) and my psi is always 1-1.5 psi from where I set it two weeks before. I change my air filter every 10k whether it needs it or not (high desert). I do a drain and refill of my ATX fluid at every OCI (Valvoline Mercon V).
I drive a very boring, very predictable commute (Hwy 14) and I only have a total of 5 stop lights from my door to my office. 70% freeway, 30% city @ 65-70mph is my normal driving habits. I did NOT drive any different for the last 700 miles, compared to my first 17k miles.
So, I would love to hear any body's opinion on why the improvement with $1 conventional oil vs $8 100% TRUE synthetic (Grp IV base oil) oil. I tried to give as much info as possible so you could come to your own conclusions.
Darryl
Darryl
