Most wrench sets don't contain a 18mm wrench ?
SE
I have several combination and socket sets. Mone of them have a 18mm wrench. Of course I never knew I needed on until after I started working on a mid 2000's Volvo. Forunately I found a neighbor that had previously run into this probelm and had pruchased some. I may have to be on the lookout for some (yard sales etc) in case the need for that size arises again.
18mm is something I find on the oddest places on my Jeep. And 15mm. Every socket and wrench set I have seen is always missing these.
I now have multiple sets of each.
It's the same reason a lot of wrench sets skip 20 mm. Those sizes are not used much.
Now, that doesn't mean you don't need them. It all depends what you work on.
I find 18mm to be a popular size for suspension fasteners. With suspension being some of the toughest work, I like to arm myself with all different types of sockets and wrenches in that size when tackling these tasks. A thinwall, 12-pt, 3/8" drive socket just doesn't do it.
Again, it's a mystery why tool sets skip over that size.
And if you are BMW you like to use different sizes for the bolt head and the nut.
I don't know where you guys are buying your tools from. All the tool manufacturers I shop from have the 18mm in the wrench sets. If you were a tool dealer and rolled up to a shop without including 18mm in your wrench sets, they'd tell you to get lost and never come back.
+6 on the suspension stuff. I think the inner thread diameter is some industry standard but they shave a mm off the outer to save metal, unsprung weight, and/or give more access. The castle nut on a ball joint of a FWD car is a great example.
I got a "great neck" 18mm wrench some-odd years ago and have used the open end on a pretty night nut, hammering the other end with a 2 lb sledge and it hasn't deformed yet.
Seriously, my MATCO sets all came with 18mm. I bought individual wrenches up as high as they reasonably went for doing alignments.
18mm is also popular on power steering pressure side hoses on Chrysler and gm. That is why I bought a 18mm flare nut socket
I had this issue with 14mm as well. I now make sure that the socket sizes are all increasing by 1 from smallest to largest when I buy a new set.
bmw might spec different grease for the nut and the head
Which at first I didn't get... Until I realized it meant I could do anything with just one set of wrenches or sockets without need to duplicate. Not a bad philosophy once I thought about it...
Ford as well.
P-steering lines were 18mm and I ended up buying a metric crows foot set, crows foot flare set, and metric stubby wrench set to deal with them. Now in hindsight, I could have gotten by with a single 18mm of each item, but noooo. Tool purchases are impulsive when young.
