Curious if anyone else might be experiencing the same thing ... or else to warn others about the phenomena.
New 2005 Subaru Impreza WRX STi (2.5L turbocharged flat 4 boxer, rated at 300/300). No modifications.
1) I changed the oil at 394 from the factory fill to Mobil Drive Clean 5W-30. I should have sent a sample in to blackstone of the factory fill ... oooops, I didn't.
2) Changed oil again at 1164 miles. With only 770 miles on a fill of Mobil Drive Clean 5W-30, the viscosity was almost out of grade (54.2 when normal is 54-61).
http://www.bescaredracing.com/sti/oil/analysis/1164.jpg
3) Changed oil again at 2210 miles. With 1046 miles on a fill of Mobil Drive Clean 5W-30, the viscosity was already out of range (52.9 when normal is 54-61)
http://www.bescaredracing.com/sti/oil/analysis/2210.jpg
4) I'll be checking my newest fill of Mobil Drive Clean 5W-30 at ~3000-3500 miles. I was originally going to go to 3500 but with the shearing in the last 2 samples I think I might just pull the oil at 3000 miles and swap to something else.
I was thinking of swapping to Mobil's 5W-30 Blend for a couple oil changes before going to full synthetic. However, with this shearing going on I might just hop on over to full M1.
Any thoughts on the shearing or swapping to full synthetic instead of the blend?
