http://www.mobil.com/USA-English/Lubes/PDS/NAUSE2CVLMOMobil_Delvac_1300_Super.asp
I'm impressed with the spec's of this oil. Both meet API SM and have a Tbn of 10.5. Has anyone considered using the 10w30 in their car?
Quote:
Mobil Delvac 1300 Super 10W-30 and 15W-40 are extra high performance diesel engine oils that help extend engine life in the most severe on and off-highway applications while delivering outstanding performance in modern, high-output, low-emission engines including those with Exhaust Gas Recirculation (EGR) and Aftertreatment Systems with Diesel Particulate Filters (DPFs) and Diesel Oxidation Catalysts (DOCs). Fully backwards compatible, Mobil Delvac 1300 Super will also deliver the same exceptional performance in older conventional engines. As a result, they exceed the API CJ-4, CI-4 PLUS and CH-4 service categories as well as key Original Equipment Manufacture (OEM) requirements for 2007 engines.
Mobil Delvac 1300 Super is the result of extensive cooperative development work with major OEMs and is recommended for use in a wide range of heavy duty applications and operating environments found in the trucking, mining, construction, quarrying, and agricultural industries. These products will provide outstanding protection in the most demanding diesel engines of Caterpillar, Cummins, Detroit Diesel, Mack, Mercedes Benz, Navistar, Volvo, and others. Mobil Delvac 1300 Super also meets the API SM specification for gasoline engines and mixed fleets.
Quote:
Mobil Delvac 1300 Super 10W-30 and 15W-40 are formulated with a) optimized baseoil technology containing severely hydroprocessed base stocks, b) patented Trimer* additive technology and c) a mixed detergent system to deliver cutting-edge performance in both new and older engines. In addition to assuring excellent control of oil thickening due to soot build-up and outstanding TBN retention for long drain intervals, Mobil Delvac 1300 Super's advanced technology also provides outstanding resistance to oil consumption, oxidation, corrosive and abrasive wear, and high temperature deposits.
* Trimer additive technology is a patented additive technology that imparts outstanding wear performance, effective oxidation resistance and improved frictional properties while contributing little to the overall ash content enabling Mobil Delvac 1300 Super to deliver performance beyond the boundaries of industry requirements of API CJ-4.
