Previous oil changes were:
575 factory fill changed out with Castrol GTX 5W-30 and Mobil-1 M1-209 oil filter.
3010 Castrol GTX 5W-30 changed out with Mobil-1 5W-30 SS and Mobil-1 M1-209 oil filter.
6025 Mobil-1 5W-30 SS changed out with Mobil-1 5W-30 SS and Mobil-1 M1-209 oil filter.
9025 Mobil-1 5W-30 SS changed out with Mobil-1 5W-30 SS and Mobil-1 M1-209 oil filter.
12029 Mobil-1 5W-30 SS changed out with Mobil-1 5W-30 SS and Mobil-1 M1-209 oil filter.
15057 Mobil-1 5W-30 SS changed out with Mobil-1 5W-30 SS and Wix oil filter - I'll edit later to put in exact one.
19928 Mobil-1 5W-30 SS changed out with Mobil-1 5W-30 SS and Wix oil filter - I'll edit later to put in exact one.
Results:
My comments: Only thing that this is my first run on the Wix oil filter, instead of the Mobil-1...interesting that wear metals are down...maybe having more flow - if it is true that Mobil-1 filters might not flow enough all the time, and Wix do - is better than higher filtration...complete speculation there though. Also, I started using Amoco 89 octane instead of Amoco 93 octane... Other than that, good amount of highway driving at high speeds...in fact I made a 5 hour trip at high speed and then took this sample when I changed the oil right afterwards...and
General BITOG UOU Observation: We've got to get a better method of entering the data in the website...if I have the free time...yeah, like that'll ever happen...I'm going to try and find a web-based database tool that we might be able to use...that way when everyone inputs their numbers, not only would they just have to type in numbers...elements field would already be there...but it would be stored for searching. So much to do, so little time...
[ July 11, 2004, 11:48 AM: Message edited by: chucky2 ]
Results:
Blackstone Comments: This oil was run 4,871 miles in the engine and the TBN still read at 5.8, so you haven't hurt this oil any during your last use cycle. Using the extra 1,800 miles for the last fill of oil, wear in most of the metals actually improved. The used oil was in perfect condition and readings for silicon and insolubles are steady. We may be missing something but we think you are far better off with the longer oil use intervals. Heck, try 5,000 miles for the next sample. This Ranger engine seems to enjoy the longer oil use intervals. No harmful contaminants found in this sample.code:
Element 19928 15057 9025
Aluminum 3 4 4
Chromium 1 1 1
Iron 14 19 16
Copper 5 3 3
Lead 1 2 0
Tin 3 2 3
Molybdenum 59 69 77
Nickel 0 0 0
Manganese 1 1 1
Silver 0 0 0
Titanium 0 0 0
Potassium 0 3 1
Boron 138 157 155
Silicon 11 10 9
Sodium 6 4 7
Calcium 2938 3120 2887
Magnesium 13 14 20
Phosphorus 756 730 799
Zinc 909 825 910
Barium 0 0 0
SuS@210F 60.9 59.3 61.3 should be 54-61
FlashpointF 410 385 385 should be >365
Fuel %
Antifreeze % 0.0 0.0 0.0 should be 0
Water % 0.0 0.0 0.0 should be 0.0
Insolubles % 0.3 0.3 0.1 should be
TBN 5.8 5.4 8.5
