Aluminum: 43
Chromium: 2
Iron: 39
Copper: 19
Lead: 2
Tin: 0
Moly: 153
Nickel: 1
Manganese: 37
Silver: 0
Titanium: 0
Potassium: 0
Boron: 151
Silicon: 19
Sodium: 17
Calcium: 2215
Magnesium: 37
Phosphorus: 1024
Zinc: 1437
Barium: 0
cSt Viscosity @ 100 C: 13.2 (should be 16.30-21.89)
TAN: 2.06
TBN: 7.0
KF: 1004 (should be < 750)
Flashpoint: 350 (should be > 400)
Oxidation: 38 (should be < 20)
Nitration: 12 (should be < 15)
Fuel: 1.03
Soot: 0
Glycol: 0
Viscosity Index: 138
5 oz of LC20 at start, and 2 oz every 1,000 miles. Also used FP60 consistently.
This was from a gallon jug of the old "Red Cap" 15W-50 that I have. I'm trying to clear out all the strays from my garage, and there's clearly a reason I no longer buy Mobil 1 for my motorcycle--it stinks in this application! I know that comparing results from different labs is imprecise, but it's clear from the spikes in iron, copper and aluminum that M1 just can't protect this bike very well. The fact that it sheared down to a thin 40-weight isn't very appealing, either.
I was happy to see that the lead wear continues to drop, though.
For this OCI I switched to an OEM foam air filter and used the NoToil products, as a couple of friends with the same model of bike are seeing better filtration with them. Unfortunately, it doesn't look like that combination works for me, as the silicon and sodium are still at the same levels as before. I guess the only thing this really tells me is that it's probably not the air filter that's at fault. There must be a leak somewhere else in the intake that's letting dirt in. I guess I'll have to get some starting fluid and spray it around the intake system and see if I can find a leak that way.
