As others have alo mentioned, the main problem is the OCI here. You are ruining your engine by running that long. Follow the manufacturer's specs whatever they are and in no case more than 5,000 miles or one year, whichever comes first. Bearings will fail anytime otherwise due to corrosion-induced lead wear.
Here is the response I got from WearCheck regarding FTIR:
Hi Gokhan,
FTIRs work by an auto-reference algorithm and the results are strictly an estimate of what the FTIR program calculates for the values. With the older FTIRs, you had to have a baseline of the actual product and process the used oil sample against it to establish true values. This is typically not done by used oil analysis production laboratories as it would require a baseline reading of each individual new oil product requiring the lab to know what the exact product was before processing. Very impractical, and clients often do not report the specific product anyway so you are still left with an estimate. What I did with your samples was to use the new unused values of the new oil as the baseline and subtracted them from the readings of the used oil. I did not adjust any of the new oil values.
I read the Bobs the Oil Guy forum, though I’m not crazy about the forums. We do redundant testing on all new oils, so I am very confident in the results. It’s supposed to be Mobil 1 0W20 made for Toyota but they may have made some formula changes for Toyota.
