Originally Posted By: SirTanon
Originally Posted By: rdalek
One last comment. I also find it funny that, of your 109 posts on here, all but a handful are about Z-max. 109 posts, and all but 15 are defending Z-max? For someone who claims not to use it, you sure spend a lot of time and effort defending it.
Methinks thou dost protest too much..
Employee maybe? There is no logical reason that someone who doesn't use it would defend it so hotly. Unless your job depends on it.
To SirTanon.
(Point 1)==>I find it odd that a HUGE number of posts here from MoleKule are anti-Zmax or anti-something else.
(Point 2)==>Actually, I believe every post he makes on the topic of Zmax is against it. Does that mean he has a interest in giving Zmax a bad name? After all, he hasn't proven a thing or changed the claims a bit. Also, Trajan is basically in the same creek MoleKule is in. So is dave1251 as well. What does that say about them you think? Well?
(Point 3)==>Does it not say something to you?
(Point 4)==>You seem to think I have some reason for posting what I post so what do you think about what they post?
(Point 5)==>Or does that only apply to people you disagree with?
(Point 6)==>If so, then what does that say about you as well?
Regarding Point 1:
HUGE? I don’t know if I’d say that. He’s got well over 14,000 posts on BITOG, and I’ve read countless of them on other subjects. As there are only a few threads that I can find on Z-max, the math would suggest that the actual percentage of his posts about Z-max is pretty low. Even if we estimate that he has posted at least as many posts about Z-max as you have, he still only has about 90 of them. Let’s double that because he’s replied to Dave too. Heck, I’ll double THAT, and estimate that he MAY have posted somewhere around 360 posts about Z-max. That places his Z-max percentage at about 2.52%, and I’d say that number is on the high side. Hardly HUGE.
I can’t say the same for you. Of all your posts (all 116 of them), only 15 are NOT about Z-max. This places your Z-max percentage at ~86.95%. Ouch.
Regarding Point 2:
You think every post he makes about Z-max is negative? Dunno, maybe.. maybe not. I’m not digging through 14,000 posts to find that out. Feel free.. and by all means, please post your results here – I think that would actually be the first time you’ve posted real quantitative analysis on BITOG. Might gain you some points.
Regarding Point 3:
Having read enough other posts from these gentlemen elsewhere on BITOG about a multitude of subjects, it’s clear to me that they know the subjects on which they speak. They are clearly intelligent, and clearly come from a scientific background, and base their discussions on sound physical and chemical principles. As this is a forum based on motor oil, physics and chemistry are both cogent fields of expertise, and so they are clearly qualified to present facts and present educated opinions. To your point, if it tells me ANYTHING, it tells me that what they say carries some weight.
Regarding Point 4:
Read my response to point 3. What do I think of what they post? I think they know of what they speak.
Regarding Point 5:
In this case, it applies to you. Disagreement is not a bad thing – in fact, disagreement is often what leads to interesting discussion, and to progress. You, on the other hand, are just disagreeable. Confrontational too.
Did I mention outmatched? You’re that as well.
Finally, regarding point 6:
Please read my above points. You asked me, so I’ll answer. I did well in school. I went to college. I work in a technical field for a big company, and my expertise is valued by others – it’s why I got the job, and why I am still working here. I got where I am because I LISTENED to my professors in school. I absorbed the knowledge they had to share. Sure, I questioned things from time to time, but when a rational explanation was presented to me, I processed it and I accepted what those who knew more than I did had to teach me.
It’s why I came to BITOG, and it’s why I’ve learned so much from people like MoleKule. They clearly know their stuff, and I am glad I can learn from it.
Perhaps you should consider doing the same.
Point one. Every post I have seen, is anti-Zmax and I have seen others that are anti-something else. I see a pattern. It seems the only thing he supports was what he failed at. I'm basing that on posts others have made about it. I was also talking about the Zmax posts, not posts in general.
Point two. I have posted court docs that to this day, NOT one single person can change with their so called "proof". I have backed up what I have posted, many times and no one has been able to prove anything different. Do you need me to post them in picture form for you? I did that once before and still have them.
Point three. So far, I have yet to see them change a single claim made by Zmax. That shows who knows what.
Point four. I think you are wrong, badly.
Point five. It was MoleKule that resorted to name calling. It was not me. It is also Trajan that seems to think I work for Zmax but has no proof, just his thinking like everything else he posts. Also, Trajan claims it was me and Dave5358 that took this thread off topic when it was HIM that mentioned Zmax first. So, you would be wrong again it would seem.
Point six. It seemed to die on the vine according to the above points. Opinion based on facts that doesn't match up.
Originally Posted By: dave1251
You have not answered how if the makers of zmax had favor for a judgement why did zmax pursue settlement with paying restitution rather than receiving payment from the federal government. Please tell. I am blowing your mind again.
Also if you can not answer my question for MMO and will not talk about MMO do not post in a MMO thread. Another mind explosion?
You still can not prove anything that changes what Zmax left the court WITH either can you? Again, if you OR anyone here has so much proof, why don't you get up and do something with it? Reason, you don't have any proof. The fact still remains, Zmax is selling its product with claims you say are false and you and no one else here can do a thing to change it. You just post on here like you know and can prove something when it is blatantly obvious you can't or you would have already.
dave1251 said:
4: This is an MMO thread.
^^^This
This was supposed to be a MMO thread. My how it has gotten off topic. I have been watching the arguments on this thread turn from MMO, to ZMax, to all out legal brawls. OP, I like MMO. There I said it. I still use 20% MMO in my crankcase. Hopefully this will get the argument back on track!
Trajan is the one that first brought up Zmax. Go talk to him. I posted a screenshot earlier to hopefully put that to rest. I think it was on page two if you want to go look for yourself.
I to use MMO. I'm happy with what it does for me and plan to continue to use it.
