Zee09
$200 Site Donor 2023
Can they PM you and if so can
you respond back?
Or do they first have to change their settings just to send one?
you respond back?
Sounds like you can do it even if they run from you.If they follow you I think you can send them a message. If they have it set to where no one can send it then even if you follow them then you can’t send one.
Additional note with this setting - I presume it will work this way too - is if 'they' send you a PM (they initiate it), you can send PMs back.1. Nobody - Pretty straightforward, nobody can send them a PM (exception would be a moderator)
Yes, I tested this with the op.Additional note with this setting - I presume it will work this way too - is if 'they' send you a PM (they initiate it), you can send PMs back.
What does "follow" do? Does it auto-stalk chosen members and bring their latest posts up in a convenient 'Targets' list? Does the target know its happening? In my account, under 'following' I saw a member name. Didn't recognize the name, must have been an accident. Promptly unfollowed. No hard feelings, okay?
No idea.It's basically the same as the "friends" list we had before on the old software.
Guessing you didn't use that feature then, lolNo idea.
Affirmative.Guessing you didn't use that feature then, lol
