Originally Posted By: MrRPM
Originally Posted By: BlueOvalFitter
Originally Posted By: badtlc
I run the FL910S for 2 OCIs on the Escape. No problems changing the filter every other OCI so far.
Used engine; $2511.00
http://www.automotix.net/usedengines/200...CFRRynAodEHUA9w
MC FL-910S filter at WM; $3.97
so Blue would you say its ok for someone using synthetic oil to do 1 OCI of 8k miles with 1 filter but not ok to do the same 8k miles on a filter with 2 OCIs of 4k miles?
or what about 2 OCIs of 3k miles with only 1 filter. most filters are proven to last 6k miles no problem. so why is it that adding fresh oil to a filter midway in it's life going to cause it to fail Vs. just doing the same service length but with the same oil the entire OCI.
I'm seriously asking not trying to be a jerk
I would never use the same filter on an engine even if the oil was changed with 1 mile on it.
Do you know what is in that filter from the oil change you are doing with the same filter again? Why risk ruining a $2K (minimum) engine over $3.97 and the few minutes to change it?
You tell me WHY you want to use a filter twice. Is it money, labor, because Tom, ****, or Harry is doing it, or all of the above?
And, I am not trying to be a jerk either. I just want to know what drives someone to use a filter (2) times or more on an OCI, when it's just cheap insurance.
I can't force someone to see it my way, and I won't. But I can voice my opinions on here just like any other member can, without any drama.
