Manually moving steering knuckle by hand = damage?
California
when I was moving the steering knuckles by hand to position the rack gear to remove a tie rod, I noticed power steering fluid gushed out of the pump. Did I blow a seal or damage the rack? The steering was a bit notchy after I got the truck back on the ground.
I’m sure this truck just needs an alignment to set toe/camber/caster, the steering does feel a little weird but better since taking it around the block.
You just pushed fluid back into the reservoir and it overflowed. Might be some air in it but should take care of itself. Just top it off when needed
Like the others said, air in the system. When I do that, I get the howling noise for a few/several seconds once I start the engine, but it goes away quick.
Yea, I’ve never had this issue happen with Toyotas or Subarus but then again the reservoirs had a little space. I plan on driving the truck around a bit more this week before handing it off to the owner.
Check that the reservoir is full, then with the engine running turn the wheel back and forth all the way to each side several times. That should work any air out.
NO
  • Like
Reactions: D60
And not to be deliberately pedantic, but with front unweighted so much less load on pump.
That said, OP likely lost so little he can just fire it up to pull the fluid back into system, then shut it down and top off the reservoir per the dipstick or sight line.
I puke fluid out of pumps all the time on trucks while shoving the wheels around for access to wb bolts, caliper bolts, TREs etc etc
