Originally Posted By: mjoekingz28
SOHCman, yeah I think ATF would be better than motor oil. Doesnt motor kind of seem acidic? As in, if you left a few drops on a piece of metal, over time it would degrade the metal.......
Also, you could mix WD-40 (from the gallon) and mix it with some kind of oil. I would do this in a small batch as an experiment because I can not think of what would happen! WD-40 tends to clean away grease....grease contains oil.......1+1=2???
They make "air tool oil" that may not gum up on you like the random oil did.
DON"T use the ATF/Acetone mix, as it is obviously acidic by design to help break loose rusty bolts. It doesn't belong in airtools or in engines.
