Originally Posted By: HerrStig
Originally Posted By: mjoekingz28
SOHCman, yeah I think ATF would be better than motor oil. Doesnt motor kind of seem acidic? As in, if you left a few drops on a piece of metal, over time it would degrade the metal.......
Also, you could mix WD-40 (from the gallon) and mix it with some kind of oil. I would do this in a small batch as an experiment because I can not think of what would happen! WD-40 tends to clean away grease....grease contains oil.......1+1=2???
All the discussion here about the TBN of motor oil and you think it's "acidic"? What a waste of time.
I cannot think up an example, but I "thought" I had wiped some tools down with it and it 'etched' the metal or something. Or maybe used it on a bicycle chain, or some other metal parts and it left it being 'less pretty'. So, I say, if I need to reword it, PCMO is not a good all around general purpose oil. It is made specific to run in engines. While it may seem that " since it is good enough for engines it should be plenty extra good for anything else". How is that?
Kind of the, if some is good, then more must most certainly be better line of thinking/deducing.
