burbguy82
$100 site donor 2024
- Joined
- Jan 21, 2024
- Messages
- 695
Can you substantiate that belief?Amsoil OE is a GrpIII base stock oil while M1 0w40 is a GrpIV I believe. Both oils should get the Job done for your application
Thanks, I figured as much but did not know of the existing threads. Thnaks againCompare how? A listing of typical values on a PDS isn't a measure of quality comparison.
Nevertheless, here are a few previous threads on this topic (or relevant) to get you started. Many are rife with nonsensical arguments where unwarranted conclusions are being drawn from inadequate information:
Driven DI40 vs. Amsoil Signature 0w-40 vs. Mobil 1 FS 0W-40
Any insight into which one of these oils is the best to use? Driven doesn't really publish much data on their oils which makes me hesitant. Car is a 2019 Camaro SS, heads, cam, the whole 9 yards. Originally when the car was stock I was using the GM recommended Mobil 1 0W-40 ESP Formula. It was...bobistheoilguy.comMobil1 vs Amsoil European 0W-40
I've pulled both spec sheets and both of these European 0W-40's seem very similar. I like both oils and I use both depending on the mood I'm in at the time. Well, actually I probably use Mobil1 more often as Walmart is 4 miles from my garage and Amsoil is 30 miles from my garage. I have both in...bobistheoilguy.comAmsoil Signature Series 0W-40, API SP, New Oil Reference.
Here is the next oil I will be trying. The last run of Amsoil's European 0W-40 for 11k performed very well considering the GDI high fuel dilution. The TBN for this oil is 12.5, and Viscosity Index is 184. Attached is the spec sheet.bobistheoilguy.comAmsoil finally has a 0w40 Signature series oil!
http://www.amsoil.com/shop/by-product/mo.../?code=AZFQT-EA Kinematic Viscosity @ 100°C, cSt (ASTM D445) 14.8 CCS Viscosity, cP @ (°C) ASTM D5293 5836 (-35C) 8.1% NOACK, 3.9 Shear Viscosity, and 12.6 TBN If I needed a 0w40 oil, this would be it.bobistheoilguy.comAmsoil "equivalent" to Mobil 0w40
Well, I have been looking into becoming an Amsoil dealer, as their product is not all that readily available in all the grades locally, and I wanted to get my hands on those filters!!! SO, if I'm running their filters, I figure it's probably best to be running their oil to make things...bobistheoilguy.comSwitching from Mobil 1 to Amsoil?
I'm sorry if this has been discussed - I searched and didn't come up with any solid answers. Search was bogged down with comparisons. I just purchased a car (1996 Z28 w/39k miles) that has been running on Mobil 1 for it's entire life (since 1k miles). I put Amsoil in my other vehicles. Is there...bobistheoilguy.comMobil 1 Vs Royal Purple vs Penzoil Ultra vs Amsoil
who makes the best 0w-40 quality synthetic oil for my 392 hemi engine Thanks and I apologize if this question has been asked beforebobistheoilguy.comIs Mobil1 0w-40 A Group IV Oil ?
Lots of internet stories going around about Mobil1 being cut back to group 3 oil, not sure how acccurate that is. Since I use Mobil1 0w-40 I was wondering if it is mainly group 4 oil. Given the specs and price , I would think it is still group 4, though I know how things can change quickly in...bobistheoilguy.comWhich Amsoil European 5w40?
Was thinking about switching our '08 Beetle 2.5l to Amsoil 5w40, but a little unsure on which offering to use? The application guide shows EFM 5w40 Full Saps And below that it shows Performance: AFL 5w40 Mid Saps Not being a Euro oil expert, what is the difference? And is one a better...bobistheoilguy.comAdvice on a 0W-40 Synthetic with ZDDP year round
I am reading faithfuly in the searchs but am looking for straight simple advice. I just bought an 06 Jeep Wrangler with the 4.0l I6. I want to upgrade to a single oil for all my vehicles for Canada. Older Toyota Pickup 22RE I4 and volvo 240 B23 I4. I am planning large volume high filtration...bobistheoilguy.comAmsoil - SS 0W40 vs. Euro 0W40
I'm wondering which one is generally better for Euro applications. SS is a little bit thicker than Euro. Both seems to be PAO based - but which one has more PAO in formulation? Is there any difference in ZDDP/phosphorus content between SS and Euro? I've already tried SS 0W40 - wonderful oil...bobistheoilguy.com
Most of these are either about Amsoil SS, not OE, or are so old they’re completely irrelevant because both formulations have changed.Compare how? A listing of typical values on a PDS isn't a measure of quality comparison.
Probably. But just as relevant since none are based on any sort of actual performance test as I noted.Most of these are either about Amsoil SS, not OE, or are so old they’re completely irrelevant because both formulations have changed.
That’s the thing, Mobil1 seems to change their formulas around quite a bit with this particular oil…last time I checked it was around 40% PAO, which is pretty impressive to me. I want to run it in my Toyota Avalon, and I just might some day, but right now I tend to chicken out (it recommends 0W20, I use 5W30, but I’m itching to run Mobil1 FS 0W40 in all my vehicles).Amsoil OE is a GrpIII base stock oil while M1 0w40 is a GrpIV I believe. Both oils should get the Job done for your application
Give the 0w40 a shot let’s say for 1500 miles short interval and pay Attention to sound and mpg etc .That’s the thing, Mobil1 seems to change their formulas around quite a bit with this particular oil…last time I checked it was around 40% PAO, which is pretty impressive to me. I want to run it in my Toyota Avalon, and I just might some day, but right now I tend to chicken out (it recommends 0W20, I use 5W30, but I’m itching to run Mobil1 FS 0W40 in all my vehicles).
