For this latest run with 10k miles on the engine, I filled it with Mobil 0W-20. I ran it for 2k miles, then decided to install a bypass and continue running the oil for an addition 8k miles (10k mi total on oil).
Observations - I was happy to see viscosity stayed in grade at 56.4 versus my previous 5k mile UOA with Exxon 5W20 which thinned to 50.7, though the wear metals wear very good. However, I expected a beter Flash Point from M1 than 385F (Exxon's dino 5W20 was 405F). Iron at 9 ppm seems to be in line with the increase in miles on the sample, but I would have hoped for a level closer to the last UOA (5 ppm) with the installation of the bypass filter. Finally, insolubles at 0.4% is still safe but I thought with the two filters working it would have been less. I would assume a TP bypass filter would have performed better.
Next Steps - I refilled with M1 0W-20 again, changed the filters and will run the next sample to 15k miles, changing the FF filter at 7,500 and top off as needed.
