Originally Posted By: ltslimjim
First of all, the actual change to a High Mileage oil isn't bad, but the advice is.
Please, rely on BITOG for your oil needs/questions. That's why you are here in the first place, right?
Secondly, not familiar with Motomaster(sp?), but personally I prefer Valvoline MaxLife for the 'first signs of leak' if its a seal I'm worried about.
His advice for every 3 months is probably fine, but if it's less than 2,000 miles for example there is no point in changing the oil then. Go 4,000 miles(max) or 4 months(max) during attempts to get the seal to stop leaking.
Thirdly, I also have somewhat of an oil leak that appears to be coolant from the bottom timing belt cover on my older I4 1.5L Civic, but I suspect it's coolant since I have a consumption issue and it seems to be coming from the weep hole.
However, on my lower timing belt cover it's older and warped away from the block/oil pan so the weep hole may simply be catching the drip from an actual oil leak.
Yet, removing the upper belt cover reveals no fluid on the belt. Therefore, probably a water pump seal or water pump issue. I'm actually hoping that is the case and I don't have a coolant leak.
Because I got coolant in my last UOA, the thought of a possibility for cross-contamination between coolant running down the weep hole onto the oil pan and possibly mixing with the draining oil at the oil change, leaves me with hope that if I clean things up before this next change hopefully the consumption has been all right there.
PS: I'm losing coolant, and have lost about 1 quart every 1,000 miles.
Do the oil change routine outlined, consider a more national brand HM oil and go into monitor status. Removing the upper timing belt cover, especially after a full-temp cycle, should reveal some form of fluid contamination on the belt itself if it's a shaft seal(crank or cam).
True but unfortunately im not capable of removing the timing belt cover to see if its wet inside.
I dumped the Motomaster + Lucas stop leak and put in Castrol GTX high milage just now. Been reading too many bad things that can happen from the stop leak. Didnt feel comfortable and wanted to get it out asap.
