Does the varnish that LC removes degrade the oil to the point that it should be changed out early or is it no problem? I pulled the valve cover on my engine this summer, no sludge just varnish. LC was then added at 3oz/qt which really did a good job of removing the varnish. It also made the oil dark a lot sooner than normal which tells me that it is working. The main question is whether I should change this oil out earlier than usual due to degradation from the varnish or continue to run it thru the winter at which point it will have 5000 or so miles on the oil. Oil is amsoil tso 0w-30 with an oversize oil filter currently at 1700 mi on oil.
Thanks,
Steve
Thanks,
Steve
