Originally Posted By: silver1
Ordered kreen for my 2000 corolla should be in 1st of the week. Ive been topping off with rotella 15w40 trying to slow the oil consumption which seems to be about 1 qt every 400 miles . My question is should I use a thin oil with kreen or does it matter?there's about 1k on the last oil change but at the rate it uses it really doesn't matter .Also does anyone have the # for a high capacity filter for a 2000 corolla thanks.
15W-40 is thick for the winter especially for cold starts, a 0W or 5W 30 or 40 would have been a better choice.
Not to change the topic too much but, sometimes if rings are the issue thinner oil can actually slow consumption. Shell did a study which proved it, please note "if rings are the problem" bad guides and/or seals need thicker oil.
Back OT, top up with a thinner oil, and add Kreen for the last 1000 miles of the OCI. Watch the oil level once you add the Kreen, it flashes off pretty fast. JMO
I found out after I bought this toyota that the 98-02 corollas have a problem with the oil return holes, they are to small and if you follow toyotas 7500mile OCI with dino oil they will clog Iam hoping the kreen can help. btw my compression in all 4 cyls is close to 200 thanks
