Originally Posted By: Trav
To be honest i'm not seeing the results on Mea's engine either.
I think the problem is the high temperatures he lives in combined with engine heat is just flashing most of the solvents off before it can work.
This product being a solvent and doesn't need high revs or long drives to be effective, in fact cooler temps and shorter runs where it stays in the engine longer is probably best for internal cleaning.
Trav: If you look closely, you’ll see that it is working. Two things to note though:
1. It's the top end of the engine that only get splashes of the engine oil.
2. I don't believe that temperature is an issue here. Yes' of course I don’t want to have Kreen in the summers here when it's 47 Deg. C ambient here. If you say that short trips are better in cold weather, consider that even on the shortest trips, if you always warm up your engine, the temps in the engine is in the 65-85 Deg. C. depending on season. And that is enough temp for ½ a litre (1 quart) of any solvent to evaporate/flash off. Kreen, IMHO, is meant to evaporate, leaving behind a detergent residue in oil that does the cleaning.
Example: At the end of any short trip, the engine even in this winter sits to cool off from 70 Deg. C. to ambient temp... And the Kreen starts to evaporat. The ambient can be as cold as ZERO Deg. but the engine operates at a certain temp. So the Kreen evaporate argument is nul here.
