Quote:
But, isn't the Baldwin rep saying that the B50 filter is rated as Beta75=2 microns?
Almost ..and when you see the difference you'll chuckle too.
74/75 = 98.67% ..commonly stated as 98.7%
79/80 = 98.75%
That's why I figured that they worked it from a 2um particle angle.
So, it's really nothing to quibble about
Nominal refers to 50% efficiency. The difference, when viewing the WIX data, is that the one we see on the bottom of the filter data is for a "single pass" test. This doesn't yield all that high a rating. When you view most oil filters on WIX, you'll also see a Beta ratio: 2/20 = 12/17. Here they kinda put things just a little backwards ..but what they're allegedly saying is that @ 50% (1/2) the rating is 12um and @ 95% (19/20) the rating is 17um (or whatever) ..but for hydraulic filters they don't bother giving the multipass spec's.
L@@kie here
Part Number: 51516
UPC Number: 765809515161
Principal Application: Ford/Mercury (81-07), Chrysler/Jeep (02-07), Mazda Trucks (94-07)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.828
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=14/31 multipass
Burst Pressure-PSI: 275
Max Flow Rate: 7-9 GPM
Nominal Micro Rating: 20 single pass (allegedly)
So, you integrate that as
Beta ratio: 50% 14um 95% 31um (multipass)
Nominal 50% 20um (single pass)
Otherwise ..the two numbers just look all wrong.
btw-Just about all Wix hydraulic filters in the lower pressure ratings are 10um. There are those that are finer.
Here's a Donaldson filter
P165332
Click to view larger image HYDRAULIC FILTER
HMK04/24 Element assy, 5 micron absolute, 9.4'' long
Hydraulic Filters Product Attributes
B - Thread Size (Inches): 1 3/8-12
C - Length (Inches): 9.44
D - Gasket OD (Inches): 2.76
E - Gasket ID (Inches): 2.48
Product Type Description: HYDRAULIC SPIN-ON, DURAMAX
Primary Application: Donaldson HMK04 ASSEMBLY
Media Type: Synthetic
Efficiency Beta 2 (Micron): 2
Efficiency Beta 20 (Micron): 3
Efficiency Beta 75 (Micron): 5
Application Note: SYNTEQ Media #2
Now here's the Wix that it crosses to.
Part Number: 51496
UPC Number: 765809514966
Principal Application: Various Hydraulic Applications (3 micron)
All Applications
Style: Spin-On Hydraulic Filter
Service: Hydraulic
Type: Full Flow
Media: Wire/Glass
Height: 9.490
Outer Diameter Top: 3.810
Thread Size: 1 3/8-12
By-Pass Valve Setting-PSI: None
Beta Ratio: 2/20/75=2/3/
Burst Pressure-PSI: 1000
Max Flow Rate: 24-28 GPM
Nominal Micro Rating: 3
They just don't give you as much data as Donaldon
