Originally Posted By: miami993
Your engine, stock, spec'd an oil with an HTHS of ~3.0cP. Any of the oils we are discussing are notably heavier here, and heavier than the spec oil for the ZL1 'vette too, which is your basic ~3.0cP HTHS synthetic 5w30.
Thank you for chiming in OVERKILL,
This last build is way far from stock, and faster by ~ 2sc vs. a 2012 ZR1 from 100mph to 180 mph, all NA.
It is the third powerful stroker running in my car and would like to give this time the bearings the best available protection...hence my reserch.
You are quite welcome
Not that it is all that similar, but my buddy with a TT termi that made 750RWHP in "street" trim and 850RWHP in "track" trim just ran plain-Jane M1 5w30 in it,
which I found surprising at the time. He had no durability or wear issues with the engine. Mind you, he wasn't twisting the car to 190+Mph either.
What grade did the engine builder recommend? I know Ford recommends a relatively shear-prone 5w50 for their high HP applications including the new Shelby GT1000, which, as the name suggests, makes 1000HP.
What I'm digging at is that even though your engine is far from stock, as long
as it is running somewhat stock clearances, you don't need to jump into an oil several orders of magnitude heavier than what it took stock as long as you have reasonable oil temperatures, which, from what you've posted, you do. Something in the 40-weight range is a safe bet. Somebody posted on here that GM's race Corvette's run M1 0w40. That, or D1 5w40 would be my recommendation, with a few UOA's to see how the oil is holding up in terms of shear and fuel dilution as well as how it is trending.
Good post.
Im no expert but if the bearing clearances are stock,or very close to stock,and the vehicle has an oil cooler then the engine doesn't need an extremely thick oil. If compression is really high then fuel dilution may be an issue.
An external oil cooler can make a huge difference in oil temps,which reduces the need for a really thick oil.
The engine will rev with less restriction and cold pumpabilty is increased. Win win in my head anyways.
