Originally Posted By: kschachn
A good way to try and isolate that is to connect your modem directly to the NID and run a (short as possible) piece of CAT 5 back to your computer. This is sometimes described as a "home run", but that generally means putting a whole-house DSL splitter in very close to the NID, with the modem immediately after. Then you connect the modem to your router and the longest runs of cable are CAT 5.
My set-up uses one NID between the computer and phone jack in the wall - that is a "DSL Gateway", in this case an ActionTec model GT704WG.
My DLS gateway/modem setup has always been hard wired with Cat5 (~5 ft long) between the gateway and the computer. This gateway is wireless capable, but I have it shut off. I only use the wireless if someone with a laptop needs to connect to the internet. I have checked all the cable connections on the phone line and Cat5 line - all seem good.
When the DSL signal is allowed to run through the sometimes mess of telephone wires in a house this can allow interference. Locating a splitter as near to the incoming wire as possible, and converting the DSL signal there can help.
The CenturyLink tech guy on the phone supposedly tested the phone line up to my house and said it was OK. It's possible something is wrong with the telephone wiring in the house, but it would have to be an intermittent problem that just started a week or so ago. My telephone service seems to work OK all the times I've used it.
I'm starting to think it is my DSL gateway/modem slowly going out - it's getting pretty old. The CenturyLink tech guy was amazed it's still working. Today I had 4 tabs in Firefox all trying to refresh and they were all grinding away for a couple minutes with no network activity seen in Task Manager. I power cycled the ActionTec and it seemed like that fixed the issue and I could then reload all those tabs.
Since I'm not ready to go buy a whole brand new computer system yet (I need to do lots of research), I guess I'll go buy a new DSL modem for $70 and give that a try. ActionTec GT784WN looks to be a good one these days - in stock at Best Buy and only a few bucks more than on-line so I'll go get one locally.
