At work, there are some pretty big fans to shift air into the boiler furnaces, and flue gasses out of them.
The original design of the (cantilevered) shaft required shaft destruction to replace the bearings. & years ago, the design was changed to allow bearing replacement (tapered sleeve adaptors), but due to the shaft stiffness, the bearings were made bigger (10 inch roller centreline).
As a result, the spherical roller bearings are quite underloaded, and have been skidding. Operating temps were up to 110degrees C. We weren't seeing much damage, just temperature. (and ultimately sludge)
So we changed to a Castrol Synthetic oil. Temperature stayed up there, but the oil lived for just over 18 months with no dramas (changed annually, and there's only 5 litres per bearing).
The other day, the operators announced that the bearing was "hot" (about 130C). Inspection revealed that someone had opened the drain valve, and the thing had been operating oilless for 4 hours.
Refilled while running, and the temperature came to 55 degrees and stayed there - didn't move. Bearing vibration had increased from 1.4gs to well over 5.
Ran for another three weeks before we could pull it out, and it's shagged.
Still didn't get above 55 degrees 'though.
Nope we never found out whoe opened the valve (and removed the plug from the valve outlet).
