Quote:
Quote:
Quote:
I have a fairly accurate dial gauge built-in to a bicycle pump (A Silca "Pista"), but the chuck is for the narrower presta valve. I could probably get a chuck that's compatible with car sized Schraeder valves.
I thought I was the only one who used a Silca to top up car tires. I have an "old school" orange one with the world champion bands on it, and I installed a Shraeder head on it. This is not a newer "pista" high pressure deal with the wide wood handle (which I have for my good tubular/clincher presta valved bike tires), it's the old one with the small black plastic handle which is not ideal for high volume auto tires, but it works, albeit with A LOT of "exercise".
That's exactly what I've got. I've bought two over the years. The rubber sleeve inside the chuck wore out on my first one, and I replaced it. Most of the repair parts are readily available at bike shops. I stored that in a room at work where we'd keep bikes, but it got lost when they started storing additional junk and I couldn't figure out where it went. I still have my second one. That design was so simple, durable, and easy to repair. It wasn't like their frame-fit pump, which resisted efforts to pump above 80 PSI and had a lousy plastic body that cracked easily. I had it shoot through a few times where the pressure would cause the body to fly away from the head. For that use, I preferred a Zefal HP-X, which had a twist ring that locked out the spring when I needed to pump and a head that could easily be switched from presta to Schrader. I tried using the Zefal to pump a car tire once and gave up.
I actually use a $12 Schwinn branded (made by a third party) floor pump for my car. It's got a wide barrel and pumps rather quickly. I think it also has a sleeve that can be turned around for a presta valve. 20 strokes adds around 5 PSI to my 205/55R16 tires.
