To stop & start I'd worry a lot more about the battery and starter than engine wear.As many of you know, I do rideshare for a living, and therefore drive 200+ miles a day. Lately it's been kinda slow so there are times when I'm just sitting in the car waiting for a fare and that got me wondering, from a purely engine longevity standpoint, which is worse, shutting the engine off and restarting it 20+ times a day or just letting it idle?
Obviously I know idling is worse for gas mileage, I'm just curious which causes more wear, especially in the freezing cold Northeast winter, where 20 minutes is enough time to cool the engine to less than 100°f.
Our early Chargers (08-10) 5.7s suffered from the low oil pressure at idle and would have lifter tick all the time. When we went from idle to WOT (happens ALOT), the low pressure ramp up would wipe out the right sides of the engine. When those were rebuilt, had the updated oil pumps that would prevent this. Those engines are still in service with 200K worth of run time on the clocks. Now, the rest of the cars are trashed, but in this profession, they're considered rather disposable.Highly dependent on the engine. The V8's in our Chargers are almost all developing some ticking. Don't think we've had any failures, but we're right in the middle of ditching the Chargers for Ford SUV Police Interceptors (Explorer). Granted, its a different division from mine, so I only see/hear the cars when they stop by the jail. I do know they didn't tick when new, and they idle a LOT in a 12 hour shift. It's my understanding that the Dodge motors suffer from below par oil pressure at idle that eventually causes camshaft/lifter damage.
Absolutely true. There are a few engines that do not have adequate oil pressure at idle, especially as they age. The Ford 5.4L 3 valve is a great example of this. To some extent, oil viscosity can combat or even eliminate this issue. The 1.3m mile van used a 5.4L engine, but he chose 10W-40 instead of 5W-20.Highly dependent on the engine.
Maybe.20+ starts a day is going to wear your starter faster.
What runs the pump?Heavy duty starters designed for this purpose, and I believe the transmissions have a separate oil pump (in automatics) to keep line/solenoid pressure up while the engine is off. I know the Aisin 8 speeds (both FWD and RWD) use that method.
Fuel washing of the cylinder walls and fuel dilution of the oil.Serious question: What is the deal with people claiming idling is bad? I don't understand the logic or mechanism that would cause this to be bad.
Timely thread. I’ve had a 2012 Versa since new. Just got a crossing guard job where it’s tempting to allow a 90 minute idle to jump in and stay warm instead of start/restart. I know, it’s just a POS Versa but I wonder if it’s harmful. Why do I even worry about this s…t?? 86 K by the way.
Yes I agree. I’ve never done extended idling with this car. I’m gonna have to bundle up and shut it down. Car has been so good to me, I’d hate to kill it prematurely. The crossing guard thing is a good gig. No masks required, fresh air and exercise. I’m 70 now, couch time is deadly. Excessive idling not good for man or machine.The general rule is 1 hour of idle time is equivalent to 28-33 miles in terms of wear and oil service life. How much wear would accrue from 2-3 startups in that same hour? Well, we don't really know and likely depends on a lot of factors.
If it was me, and this was my profession, I wouldn't be able to get the thought of operating cost from fuel consumption out of my head and would want to shut it off any time I know I'd be sitting for more than a few minutes.
ah....I haven't had a carbureted engine in a car in like lets see....not in the 2010 decade, not in the 2000 decade, not in the decade of the 1990's.....why are we bring up carburetors in the year 2022? Sure shut it off because of wasted fuel but at a 1/2 gallon per hour it's hardly much of an issue.Mostly wasting fuel. Certainly it was bad for carbureted engines because there would be a high amount of unburned fuel since most tend to run rich at idle. Even if it doesn't, carburetors aren't precise enough to avoid unburned fuel. With fuel injection it isn't so bad.
Probably depends on the engine, but I'm reading that a warm start might take about as much fuel as idling for 10 seconds. It's also fairly easy on starters compared to cold starts.
Not if I can help it, I take good care of it and replace parts at the first sign of failure, do all fluid maintenance early, keep the salt off and undercoat in the winter. I've replaced most of the suspension parts because the roads here suck. The 6spd auto is pretty bullet proof, but I like this car enough that I'd replace it if it ever did go out.
It's had the suspension parts replaced, on the third set of front brakes and second set of rear brakes. The shocks struts will be replaced for a second time this spring. Motor mounts getting replaced then too. I don't mind replacing parts as they wear, I just want maximum engine and transmission life.200 miles a day is likely to be fairly easy on the engine since it will never get cold and warm starts are actually pretty easy on the starter. I remember a Pennzoil commercial claiming that a business using a pickup as an escort vehicle for oversized loads had its oil changed every 3000 miles, but that's probably not needed for that little mileage when it racks up that many miles with relatively few starts.
The brakes and suspension are going to be pretty messed up though.
Still - for this kind of driving an EV might actually be ideal since there really isn't much of a concept of needing to warm up anything. And idle breaks can be taken at charging stations.
I run either a 40 or 50 grade oil, it probably has more than adequate pressure considering the engine is specd at 14.5psi at 1000rpm on 5w20Absolutely true. There are a few engines that do not have adequate oil pressure at idle, especially as they age. The Ford 5.4L 3 valve is a great example of this. To some extent, oil viscosity can combat or even eliminate this issue. The 1.3m mile van used a 5.4L engine, but he chose 10W-40 instead of 5W-20.
Knowing the issues with the engine you operate is key on this one. However, most engines have no oil pressure issues and can idle for hours without any wear related issues. I'd choose comfort over stopping the engine every time.
