Originally Posted By: Doad
Would changing the coolant in the pressurized o/flow tank yearly have any benefit? I can get about 2.5 L out of mine which represents a little more than 1/4 of the cooling system capacity. I do believe the coolant in this tank circulates throughout the cooling system? I don't have a rad cap and siphoning the fluid out of the o/flow tank is so simple. Would this keep the system somewhat fresh?
Can someone also explain the difference between the old "expansion o/flow tank" with a rad and rad cap vs. the newer "pressurized tank" that has the pressurized cap ? Thx.
That's how I do it... I suck the reservoir empty after winter, and run a lower concentration of coolant in the summer, but as winter approches or threatens to get severe I replace with high concentration coolant again.
No need to run -36°C protection in summer (although it's less work) and the higher (distilled) water content soacks up more heat anyway. I run about -15°C in the warmer half of the year.
there's very little difference in the operation of the pressurised tanks vs unpressurized, but it mimicks more the central heater for houses, probably less chance of spills through the overflow
