Getting a doozy of a snow storm today and tomorrow! I have good tires on my 1991 Chevrolet K1500. 4WD is great but really squirrelly without weight. I put nine 70 lb sand bags between the wheel wells. Is this enough weight? 630 pounds total.
2WD or 4WD? What the good tires? If you have 2WD the you can't put enough weight in the back. If you have snow tires it's a better situation.Getting a doozy of a snow storm today and tomorrow! I have good tires on my 1991 Chevrolet K1500. 4WD is great but really squirrelly without weight. I put nine 70 lb sand bags between the wheel wells. Is this enough weight? 630 pounds total.
4WD (K1500). Firestone Transforce AT tires. Not “winter” tires but aggressive tires with good tread.2WD or 4WD? What the good tires? If you have 2WD the you can't put enough weight in the back. If you have snow tires it's a better situation.
Around 250lbs is what my Dad runs in his crew cab, short box 4x4 trucks. Seems to work good, and you don't always need to be in 4wd all winter just for the odd stoplight with some slush in it.I run 210 lbs. Already have another 30 lbs in a tonneau cover and another 70 lbs in the dual liner, so effectively 310 lbs above stock.
I run winter tires and it is amazing how this settles the truck down and makes it less squirrely, even with it being a 4WD truck.
Yep, only run it in 4WD in deep snow/slush. Unfortunately, I do not have the Dana locking rear differential, which I heard is good even in 2WD.Around 250lbs is what my Dad runs in his crew cab, short box 4x4 trucks. Seems to work good, and you don't always need to be in 4wd all winter just for the odd stoplight with some slush in it.
yes its good to put you in the ditch.Yep, only run it in 4WD in deep snow/slush. Unfortunately, I do not have the Dana locking rear differential, which I heard is good even in 2WD.
I use about 3-4 sand tubes as well here in Iowa in my Frontier 4X4. I have Yokahoma A/T tires and have found them to real pavement huggers in all kinds of weather.I run 210 lbs. Already have another 30 lbs in a tonneau cover and another 70 lbs in the dual liner, so effectively 310 lbs above stock.
I’m running a 245/75/16. The stock tire was a 225/75/16. The 245’s are what it had on it when I purchased the vehicle so I stuck with those.You've got it about right. I would want the rear axle to weigh similarly to the front one. Like they say more weight is more to stop, but you want enough for the tires to dig down to pavement vs riding on top of the snow. Assuming you're running like a 235 75r15 you're probably good.
