Originally Posted By: Olas
Engine FF
As soon as I get home from the dealership,
The end of the next day (typically 150-200 miles)
1000 miles
5000 miles
Every 5k thereafter
Gearbox FF
Every 20k thereafter
I've done a few that way myself. You have to be careful mentioning it here though.
I used to do something similar. I drain the FF at 1K, run a 3K drain on anything close to the recommended viscosity that I happened to have on hand and then go to normal drain intervals.
The only reason I didn't do this with our '12 Accord is that Honda recommended strongly that the FF be run for a full normal interval.
The FF has a lot of moly, whether from assembly lube or the fact that the old SM HGMO had 500 ppm of moly.
Was I wise to run the FF to 15% MM, about 8700 miles?
I don't know but I will know in another hundred thousand or so miles.
Nothing to apologize for either way. Oil is cheap while a good long term ownership experience is priceless.
Engine FF
1000 miles
5000 miles
Every 5k thereafter
Gearbox FF
