Radiators are going to go bad anyway because of the plastic parts and seams between the plastic parts and metal parts.Idk how much do you like replacing heater cores and radiators?
What is the life of a vehicle?I think you really only need to change out your coolant once during the life of a vehicle, and that's the first coolant change. After that it's part of another job like replacing a radiator, water pump, etc.
I would do it.... keep in mind you only change like half of what's actually in the system, so if you wait until it's totally bad, you'll technically still have bad coolant after changing it.Don't waste your money and simply change out the fluid per the recommended interval.
Change itYou would do what?
My post was suggesting not to test the coolant and to instead just change it per the recommended interval.
