- Joined
- Feb 10, 2024
- Messages
- 8
Hi,
What I did was
1. Park the car on a flat surface
2. Open the check bolt(overflow drain hole above drain bolt) and drain bolt and transmission fill hole plug
3. Let the oil drain fully
4. Close the transmission drainage bolt
5. Now put in new transmission oil
3.1L oil(THE EXACT AMOUNT THAT WAS DRAINED)
6. Turn the transmission to every gear on a running engine so that the oil goes inside all parts of the transmission
7. Now add oil and when there are only drops coming out from check bolt
8. Close thr check bolt
Please see I didn't start the engine and drive car to make the engine at operating temperature then turn off and then change transmission oil.
Is there is damage to engine if done on normal temperature engine? Have it overfilled it as engine was cold and when now the engine will get hot, the oil will expand? Should I nake car engine hot and then open check bolt and recheck and refill etx?
What I did was
