Originally Posted By: Jim Allen
No I can't agree. I've rebuilt many automatics, both as a tech and after I retired from wrenching, and was factory trained by Land Rover and Ford to do it.
As I said, any trans that dies after a fluid change was on borrowed time anyway and older Odyssey transmissions are about the worst of the Honda bunch because they make an already weak passenger car trans do the work of a minivan hauler. I think strongly that neglect upon neglect is the wrong way to handle things most of the time. You are trying to make a "general rule" based on one or a few instances. I think that is bad, BAD practice as a general rule. I would only apply your "rule" to neglected 164K mile Odysseys. The most I can agree with is that the oil change might have accelerated the death spiral a little.
Also, in the cases where I had some direct connections to something similar to what you described, the trans was not operating as "perfectly" as often described. The trans usually degrades gradually, so gradually that it appears to be "normal" to the driver. If you compared the performance to new or at least "normally good" you might have noted a difference.
Honda automatics have had so many issues over the years that they are a special breed. I regularly dance the happy dance that my nearly 14 year old Honda Accord V6 (we bought it new) has not cacked, despite meticulous maintenance.
So, you've PERSONALLY seen this many times or are you repeating what you personally saw repeated second to tenth hand on some Honda forum?
I basically grew up in a Garage, When I was a kid my father who owned a Shell gas station used to lift me up on the hydrolic hoist is what they used in them days.....
Remember they looked like this?
and back in them days Gas Stations has Garages... We had 4 Sunocos and 1 Shell gas sation and when the oil companies wanted to put FOOD MARTS and take out the garages we sold the bussiness...
Now we own a famous Auto Care / Car Sales in Michigan and I worked there from 15 years old till I was in my 30s
So I have seen it all.
Also I have a Honda Accord V6 and I take care of the Tranny very well.
180K miles on the Original Transmission
Also now garages uses Electric lifts to raise the cars... However Im sure you remember them old ones with the yellow ends that were sorta a X shape and they had Oil and most leaked a lil.
However I disagree with what your saying and only on the part of the trns filter getting clogged up after you take a dirty sludge filled trans mission and put good clean ATF in it and Im sure you know ATF is HIGH in Detergent and it cleans the transmission and where do think all that sludge goes???? It goes in the filter and what happens when that HONDA Filter gets 100% Clogged up??? There is no bypass in them
they are just a lil plastic / strainer thing
This is the sludge Im talking about
