Quick question. I once say a list that rated oil filters, but cannot find it now. Anyone have a link to it, and where do SuperTech filters place? Thanks!
Use with confidence in oci of 3-4k. I used to used them, but I came across a deal at Napa where they were selling ProSelect for .99 cents so I loaded up. I bought 10 which is well over a year worth of oil filters. Also, I won't be going back to the ST filter because the Napa(Wix) ProSelect filter is the same price of the ST filter. Atlease for my whip it is.
The construction is OK (definitely not a Wix) and should be fine for most applications where very long drain intervals (say 8-10K) are NOT involved. The only application I would avoid would be a big block V8 running 20W50, especially in colder temps.
I like the Wix made ProSelect for low cost. Here you get the Wix construction and likely similar filtration at a similar price.
The baseline orange can has similar filtration to ST. The construction uses cardboard end caps which, is not dis-similar to the eCore design. I have no problem using them except better stuff at better price.
The TG line in Fram has outstanding filtration (99% dual pass) like the Purolator PureOne but still uses paper end caps. Discounting is rare and cost is high.
The XG line in Fram has that fuzzy synthetic blend media and metal endcaps. Like it's name, it is for extended OCI app's and has more holding capacity in media. The issues I have is the filtration drops back to the baseline orange can and the cost is high.
I don't rule out Fram like most "experts". They offer products...I make selection.
Not ALL ST filters are eCore design. The ST filter that I was using on my car still had the metal endcaps. But like I stated, I'm going to stick with ProSelect from now on.
You won't find an Ecore smaller then 3". That means all you Honda and whatnot filters won't be Ecores. They can only be produced on certain lines.
I like them, but don't find them as good a value as they once were. When they were $2.02 ..I couldn't resist buying one or two every visit to WM. Now I reach for an MC instead (if I'm buying short OCI filters).
