Originally Posted By: Stooge
Originally Posted By: Petersubaru
Originally Posted By: hate2work
I didn't even know they made a special grease just for caliper bolts. I've always just used a good high temp grease.
..most of the cars in my families stable are fine with the silicone and synthetic perma products..but..if you have the rubber "dust" boots that actually grip around the "shaft of the caliper bolt" (not just below the head) like on the newer 2000+ subarus and some pontiacs (the only cars I am familliar with), the silcone or permatex products will not do the job for the long run..these types of greases don't mix well(developes unnecessary friction or welling) with the rubber boots and will start to bind up in a very short time causeing the caliper pin to hydraulic causeing the surface of the rotor to become tarnished..I was made aware of this when I bought my 2001 subi with 42k/mi, since it was dealer serviced being still under warr, by this time the rotors had been re-surfaced 2 times with 3 new sets of pads..even after my purchase shortly again the rotors and pads needed replaceing..the caliper pins were locking up and a [censored] too pull them out even though they were not one bit rusty..to make this long story short..the proper grease if the mechanics are ware of it(most are not) can not be purchased any more, at least for the consumer..so I use this product in small amounts and all works as it is designed too..
http://www.opieoils.co.uk/pdfs/FUCHS - TDS/RENOLIT RED RUBBER GREASE.pdf
This is exactly what happens on my Toyotas. I've used green and purple Permatex, and CRC synthetic brake greases that say 'rubber-safe' 'use on pins' but after awhile, the rubber swells and the pins lock. The CRC products seems better that the Permatex products. The CRC product even says that 'silicon brake greases are bad for rubber parts.' The only one that does seem to work well, is the Toyota pink brake grease that comes with the Toyota caliper rebuild kits. It says "silicone lube' on the label. I'd like to know why all of these 'rubber-safe' brake greases are not rubber safe and swell the rubber after a couple months. Funny thing, the old 2002 Corolla does not have this problem.
...the simple fact is, that the so called "rubber safe grease" can not be used for rebuilding, making it useless for our application..seems the only way to get the proper grease is having to order up the caliper repair kit and use that grease to lub up your pins..an expensive way to obtain the correct grease, be it toyota, honda, subi..even ford and gm have on some cars the need for this grease...concerning your 2002 corolla, next time look closely and compare the boots on how it surrounds the caliper pin..also the pins that require the pink/red grease have tighter tolerances then calipers with the old style boot..
