Originally Posted By: PandaBear
WEP is already cracked, and anyone with a laptop and the right tool can crack it in minutes. might as well let it open.
WPA can dog some routers that are low end and do not have enough power for it. So you probably should spend $100+ and get a gaming router, or those beefier router that can switch to Open Source FW that is updated all the time for it.
Personally I prefer to use a router that has open source firmware for the reason of flexibility. I set the transmission power just enough so signal doesn't travel too far out of the house (important in a dense neighborhood), set it to recognize only selected MAC, disabled DHCP on the local network, manually set an arbitrary network mask, and only turn on my wireless connection as need, to deter the unusual war drivers and bandwidth thiefs.
Still, there is no replacement for physical connection.
ASUS makes a few inexpensive (~40.00) routers, like the WL-520G for example that handle WPA/WPA2 easily.
