Hello, my garden hose has finally given up. I live in the desert and the high heat has gotten to it. It was showing signs of breaking down inside (bubbling of the hose) and going flat when my pressure washer tried to pull water through it. What is a good recommendation for an outside hose to use that will be hooked up to a pressure washer and be used in the desert?
Thank you
Thank you
