The short version: In my car, during my first test today, Fuel Power does not appear to function as an effective octane booster.
The long version:
My car is a 1999 VW Jetta GLS VR6, and specifies premium fuel with at least a 91 octane rating. In the past, I have run 87 octane without noticing any adverse effects, but nearly all of the fuel going into this car has been 93 octane. I have been running Lube Control and Fuel Power for about 3,000 miles and had planned to experiment with Fuel Power's reported octane-boosting properties. The recent spike in the price of gasoline led me to question whether I really needed the premium grade if I supplemented the fuel with Fuel Power.
I have the VAG-COM diagnostic software for Volkswagens, and a laptop with a 12 volt adapter. I used the VAG-COM to log the values of measuring blocks 1, 20, and 21 on the engine controller. In short, they allowed me to log a time/RPM stamp along with idle stabilization values for each of the six cylinders. The idle stabilization values should be zero if the timing is not being retarded due to knock detection. I confirmed this by logging data for the 93-octane, FP-treated tank before filling it with a lower grade. During an hour of driving, timing was never retarded on any cylinder. I added approximately 2 oz. of Fuel Power last night in preparation for my fill-up today. I added 8.965 gallons of 87 octane gasoline to my 14.5 gallon tank. By consequence, 5.535 gallons of previously FP-treated 93 octane fuel remained in the tank. The average octane value of the gasoline contained in the tank is now 89.29. During ten minutes of driving after filling up with 87, the logs showed that knock was being detected and compensated for via retarded timing on several occasions. I could not tell any difference in driveability.
Once I returned home, I added about 3 oz. more Fuel Power to the tank, in hopes of getting more of an octane boost effect than I had earlier today. I plan to continue testing how my car reacts to different combinations of fuels, with and without the Fuel Power additive. My initial conclusion is that in this application, a 1 oz./5 gallon treat rate of Fuel Power does not enable me to run regular gasoline without the engine operating in conditions that are less than ideal, due to the timing retard.
I realize that this result is contrary to what others have seen, but thought I would post my initial results to solicit suggestions for improved testing or product usage. Any such suggestions are greatly appreciated! Also, although FP did not work in this application as an octane booster, I'm sure it had other effects that are not yet measurable (cleaning out the fuel system).
Pax,
segfault
[ August 23, 2003, 12:24 AM: Message edited by: segfault ]
The long version:
Pax,
segfault
