The anti-drain back valve seems to work quite well.
When I change the oil after letting the car sit for some hours there is PENTLY of oil in that filter.
The material the ADBV is made out of is high temp silicone.
The SuperTech filters I've been disassembling are not a filter for use in a Honda application. The clicker stype by-pass valve does not function well enough to provide the required higher levels of oil pressure while engauged in VTEC (8000RPMs)
SuperTech filter ST2808... Link
SuperTech ST3593A... Link
Example of the clicker style by-pass valve in action... Link
So far as I can tell via first hand inspection... the ADBV on the WalMart filters is just about the same in thickness and so on.
[ May 12, 2004, 03:13 PM: Message edited by: gerhardb ]
