The motor guy
Thread starter
- Joined
- Nov 29, 2009
- Messages
- 7,296
What do you use to cut it open? I sold my oil filter cutter to someone on here years ago lol I can use my reciprocating saw
I've done that but there will be metal shavings in the filter by the time you're done. If you're not worried about that then go ahead but the cutter will allow you eliminate metal pieces when inspecting the media. I'd still recommend a cutter.What do you use to cut it open? I sold my oil filter cutter to someone on here years ago lol I can use my reciprocating saw
Between the endless buzz on this site - and from this same kind of view here again - I ruined this $10 filter …
View attachment 200009View attachment 200010
If no cutter available, simplest would be a hack saw. As louvers not possible shavings from cutting your main concern here, reciprocating saw could work too. Some have folded back the can with pliers and tin snips at base rolled seam.What do you use to cut it open? I sold my oil filter cutter to someone on here years ago lol I can use my reciprocating saw
Valvoline R&P4wd… what finger polish are you using ?
The Cummins has a bypass in the filter adapter built in.don’t cummins filters not spec a bypass valve? therefore all the oil HAS to go through the media?
That's not a good analogy - not even close. Flow being forced through a flow path like an oil filter and engine oiling system by a PD oil pump doesn't behave anything like that example.@The motor guy another analogy, culvert water flow. Go up only a few inches (from 10 to 12) and the water flow increase is tremendous.
The point was the hole size and its capacity, take issue with the word "flow" if you like. Are you a scientist or something?That's not a good analogy - not even close.
Oil flowing in an open conduit and oil flowing due to a PD oil pump which is forcing it through something are totally two different types of flow and have zero relevance to each other. Do you actually think the flow volume is reduced through the oil filter because the holes are a little smaller? Like said above, as long as the oil pump is not in pressure relief, the flow volume will not change, but the dP across the filter will. And that dP change is small and will not effect the pump output in normal use conditions. Do you understand how PD oil pumps work, and how they make an oiling system function?The point was the hole size and its capacity, take issue with the word "flow" if you like. Are you a scientist or something?
Then use the one with the well opened louvers. The difference in the base plate holes is an non-issue as I explained above.That's the one where atleast half the louvers in the center tube are closed off. The one below it with only 6 holes in the base plate has nice opened up louvers.
Nope, Nope, and Nope. I was talking about culverts and hole capacity i'm pretty sure! You dont really want much filtration there except to keep timmy out or seaweed, but i wont claim to be an expert there either. OP probably would like more info on the loueveurs or however that is spelled. Were they blocked? Were they open? Who knows! Lots of red squiggles on my spell check there but I just "send it."Oil flowing in an open conduit and oil flowing due to a PD oil pump which is forcing it through something are totally two different types of flow and have zero relevance to each other. Do you actually think the flow volume is reduced through the oil filter because the holes are a little smaller? Like said above, as long as the oil pump is not in pressure relief, the flow volume will not change, but the dP across the filter will. And that dP change is small and will not effect the pump output in normal use conditions. Do you understand how PD oil pumps work, and how they make an oiling system function?
No, because there is still some open flow area in the center tube, even with choked down louvers. That can create more dP across the filter and cause the filter bypass valve to open. But, it could have caused the filter to hit some bypass action with cold oil and/or higher engine RPM when the pump output is increased with RPM. It could also make the oil pump hit pressure relief sooner is the oil is cold and the engine revved up pretty high before the oil warms up some.So does that mean it's just been bypassing the filter entirely?
Yeah, you were trying to correlate flow in an open culvert to flow through an oil filter mounted on an engine. Like I said before, there is zero correlation.Nope, Nope, and Nope. I was talking about culverts i'm pretty sure! You dont really want much filtration there except to keep timmy out or seaweed, but i wont claim to be an expert there either. OP probably would like more info on the loueveurs or however that is spelled. Lots of red squiggles on my spell check there.
That last sentence shows you at least acknowledge it as a possibility. A good thing. Fwiw, the alternative is what's known as confirmation bias.The truck sure runs smoother with an oil filter that actually flows oil. Could be a placebo thing though
You're missing the whole aspect of how oil flows through an oil filter as supplied by a positive displacement oil pump. The pump forces the oil through the system, and will just keep increasing the supply pressure to do so until the pump hits pressure relief. If the pump is not in pressure relief, there will be no decrease in flow volume through smaller holes, only the dP across the base plate will slightly increase. So there really isn't a "capacity" factor involved in this case.
Your BITOG card is revoked !!I sold my oil filter cutter to someone on here years ago lol
